Hello, i think if i just re-post my original query. The whole thread has gone astray
Hello, I had a new Vaillant ECO TEC PLUS 831 installed in April, since October it has broken 4x with a F75 code. FAULT PUMP/WATER SHORTAGE
The boiler is still under guarantee another 9 years and the plumber/installers work is also, but i have no written confirmation of that.
The problem is, the plumber will not respond to any of my calls and messages any more and i have been without hot water and heating for a week. He has always been incredibly unreliable, not showing up when he's said without informing me etc after the initial installation.
If it is a boiler issue Vaillant will fix the boiler for free, however they won't touch a plumbing issue and i would have to pay a £90 call out charge then for nothing.
So i don't know whether to risk calling out Vaillant or call a different plumber. As i don't know where the problem lies.
Old boiler, no plumbing/pressure problems but needed replacing after 15 years, had tank in attic.
So far, with this Vaillant first fault was F28 - ignition, water pressure was low, taps were turned to re-pressurize. Had a leaking Rad, plumber put radiator sealant to temporarily seal it before rad was changed. (he didn't turn up to do this) But leak is still holding.
F75 x4 faults
F75 First time, turned boiler taps no water was being let into the system. Plumber came after a week, did something. Fixed for 2 weeks.
F75 - I turned boiler taps (probably the wrong thing to do), boiler leaked quite a bit. Plumber came leak on boiler stopped, worked 2 weeks.
F75 fixed, broke within 2 hours of plumber leaving.
F75 current problem
The water pressure in the Sink taps is good with and without the extra/external electric pump. Hot water not as good when bath runs without pump.
Pressure on hand held monitor and boiler reads 2.7 now. With the F28 the boiler read 2.7 on both too, however the actual pressure was bellow 1 apparently. I realize this is quite high but the plumber said that this high reading was OK, and that the devices weren't communicating a correct pressure.
While the boiler was working, the pressure used to read 3. It never let out the "bang" pressure over flow.
I do not have any other information I'm afraid. I can only assume if it was a boiler problem the plumber would have left it to Valiant? or not... who knows.
So two questions, is it likely to be a plumbing or boiler problem? As in who do we call?
Also is there anything that can be done about the unreliable plumber? Because calling a different one will incur fresh costs.
Many thanks in advance for any information and help.
