Hi, the engineer from ****** cam today to install my Nest (they were the subcontractor Nest told me to contact). The engineer had only passable English which meant I had trouble answering his questions and he had trouble explaining anything to me. Anyway, it got worse when he struggled to find how to take the front off the boiler (it's a two year old British Gas 330+ so nothing special). He then asked for the manuals for the boiler and the timeswitch and spend nearly an hour studying them apparently because he could work out how the boiler was wired up.
Eventually he seem to get somewhere and we had the Nest and the Heat Link box installed at which time he was going to leave. Not having seen the boiler fire up yet I tested it and nothing, the boiler didn't fire. He stayed and worked on it until 8pm (he must have arrived about 2:30) and when he left the boiler was firing up when requested by the Nest but nothing was coming through the radiators. I suggest it was something to do with the valve in the airing cupboard not being properly controlled by the boiler but that didn't seem to translate. The hot water seems OK. The programmer is a Drayton Lifestyle LP522.
He didn't fill me with confidence that someone will come back tomorrow as he was muttering something about the Nest not being programmed properly which sounded bullshit to me as the Nest Link Unit was making a click sound when the Nest was requesting heat it just seemed the boiler wasn't wired correctly.
So any ideas where the issue is that I might be able to point the next engineer to?
Thanks, Simon
Thanks, Simon
