- Joined
- 27 Jan 2008
- Messages
- 25,373
- Reaction score
- 2,985
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Where I work, every bit of electrical equipment needs to be on a register and have been tested and inspected, records kept of this, and a label attached to say what its plant number is when tested and when next test is due. Loosely called PAT testing.
In the home rental in England the landlord has to test all fixed equipment, items like the central heating, immersion heater, cooker, extraction fans etc. There is some debate about equipment not normally moved but plugged in rather than hard wired, like washing machine, tumble drier, fridge/freezer, reading the new landlord law it depends on who's interpretation one uses. The official guide does not seem to follow the actual regulations/law and it is the definition given in this law which is what we need to follow which says
Where the location for use is fixed due to water supplies, waste pipes and electrical sockets even if it can be moved for maintenance if it weighs over the limit to be considered portable (18 kg) and not provided with wheels, then it is likely considered as fixed, so must be tested every 5 years and the results given to the tenant.
But can't see how any Christmas lights come under this? The problem is if you go down the PAT testing route, it becomes rather expensive, an inspector can likely test between 50 and 100 items per day, at £20 an hour, so £1.60 per item, I would suggest that is not a route most landlord
what we are looking at is what does "fixed electrical equipment" include?“electrical installation” means fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter;
