Great, thanks... that'll be going straight into the stream, then
That's almost certainly illegal and could lead to huge fines
So, it can't go with surface rainwater... but also can't go into the sewage treatment plant..? That's a problem, then..! Do all water softeners work the same way... and need to 'regenerate' periodically? I was thinking we'd have a unit which uses salt blocks? Admitedly, I'm a bit vague about this... haven't researched it and was happy to leave it to our heating installer/plumber...
Also., you shouldn't fill central heating systems with softened water
I'm thinking of the water in the boiler / heat exchanger and heat store, and domestic hot water... Presumably, it would be possible to fill those with softened water, and not the central / underfloor heating system..? What's the reason for not having softened water in there..?
Apologies to OP for hijacking this thread (although it's not clear whether you're still watching...)
