Now the drunken weekend tom foolery hijacking is over......................................To the op, take safety precautions, turn on the power, poke the fan blade with a screw driver, if it spins replace the capacitor. If it doesn't spin buy a new fan.
Some types of motors use capacitors for that purpose.Do you mean the capacitor is like a starter motor?
If I spin the fan blades manually they will keep spinning if themotor is good?
Indeed - but, although I may be wrong, I would strongly suspect that the motor in a small bathroom extra fan would be one of those 'others'!Some types of motors use capacitors for that purpose. Others do not.
Hi John.I haven't yet noticed us being told whether it is or not but, as has been said, if it is a 'timer fan' then the timer board must surely be the prime suspect (unless the fan has just got 'stuck' as a result of muck)?
I confess that I didn't look at the link. However, I was aware that it spun freely and hadn't changed in sound, but worded my bit in brackets poorly - I should have written some like "(given that the fan has not just got 'stuck'....", rather than "(unless the fan has just got 'stuck' ...".Hi John. Post #1 has a link to the type of fan, no timer. Post #5 explains that the fan blades spin freely and that there was no noise change before the fan stopped.
The capacitor is a start assist capacitor. Not a suppression, power factor correction capacitor or anything else.
The following may be of use to some.
Goosed goosed goosed goosed, goosed goosed goosed goosed goosed goosed goosed goosed goosed!Every word will mean everything soon.
