hi.first time on site.i am fitting fan in bathroom cant get to ceiling rose (concrete) fan has 2 wires. how do i fit to light switch pull cord which has2 wires.will a different pull switch work?many thanks
Either find the place that the lighting wires converge (its probably in the light fitting itself, or a junction box in the loft if you have one)
If not, you'll have to take a feed from a socket circuit, and control the fan with a seperate pullswitch. You could put a PIR detector up to control it.
all wires in light. its a flat. concrete ceiling.do you mean a ordinary plug socket?. if so do i put the cable(what size) to a new pull switch.and fit the 2 wires from the fan to that??
