if you are getting power to the fan with the hot tap turned on and the fan is not running and then you tap it and it runs and boiler fires up , well i would change the fan.flanok said:One last question
I have had the fan out already, but ot turns very easy.
even by blowing on it, it turns for a long time.
is it possible that the motor can be sticking and the fan turn so easily?
Any idea how much a fan would cost an engineer? So the corgi engineer does noy quote silly prices?
Mark
chrishutt said:Flanok wants to buy one and fit it himself. He could do what we all do and look in the manual for the part number and then check suppliers on the net.Any idea how much a fan would cost an engineer? So the corgi engineer does noy quote silly prices?
B.O.B DOLE said:if you are getting power to the fan with the hot tap turned on and the fan is not running and then you tap it and it runs and boiler fires up , well i would change the fan.flanok said:One last question
Mark
Drat! I didn't think flanok might read the post.I now know where to buy one from now
chrishutt said:Drat! I didn't think flanok might read the post.I now know where to buy one from now
like to help said:how about a recon fan £45 plus post and retn of old one www.cetltd,com
Agile said:I am not convinced that it is the fan !!!
Measure the fan motor resistance with the leads disconnected, should be about 30-60 ohms.
I am wondering if its the NC connection on the APS ???
Not only does he want to buy a fan and fit it himself but he now wants to buy a "repaired" fan which no genuine CORGI registered person should do.
Tony
