E
eddiescully
I was just reading the fault finding flow chart for a baxi solo 2 50pf and as i understand when fault finding boilers a logical step wise approach is required to quickly track down, isolate and repair faults and that you have to understand the concept and principles of the boiler conponents and how they work in relation to eachother and not just learning thr details of one particular model and expecting all others to be just like it but as i was just saying the baxi solo flow chart says- does fan run (no) - is lockout light on (no) - is "fan on" light on (no) - check control knob is turned on - check that the wires are connected to the thermostat sensor - check that the fan and APS plugs is connected - check continuity across sensor (1 M OHM at 20 degrees) - no continuity change sensor - check continuity across pilot solenoid (1.5 K OHM) - no continuity change pilot solenoid - check potentiometer. I cant understand if a logical step wise approach is applyed to fault finding why the hell would i be checking for continuity across the pilot solenoid when the problem is that the fan is not running, i am not that far into the ignition sequence to be checking the pilot solenoid???? Please explain
