A friend of mine recently asked me to go to a job he was working on as he had broken his hand and was unable to work. When i arrived i found out that there was a fault on a 100m lenght of SWA, which was buried underground, after speaking to the customer it became apparent that he had fallen out with his neighbour and his neighbour had already put a screw through the underground water mains so we assumed he had done the same with the SWA.
So here i was tasked with finding the fault after speaking with my electrician friend we decided the only way to find the fault would unfortunatly be to dig up the cable in the centre of the run and then test which side of the cable the fault was on and then repeating this another four times until we found a length of cable which had to be dug up until we found the fault, which also happened to be a screw.
Now after finding the fault and leaving it in the customers hands and not hearing off him for a while i've just decided to give him a ring and he tells me he has got another electrician there who questioned why it had been cut so many times, as he says there is a machine that can pin point where exactly the fault is on the SWA.
I've never heard of this myself and was just wondering if any of you had any experience of it and whether i had gone about it in the right way bearing in mind he wanted the piece of cable with the screw in to use as evidence as he has gone to the police.
