it is possible for a disc meter to creep under the influence of the voltage coil only, during the checking/calibration this is one of the tests that it remains stationary
As I recall it doesn't add to consumption when the meter is under load.
The difficulty with re-assessing bills is proving when it started to creep as it would have been correct when originally installed.
(though if it is outside it's calibration period that could be taken into account
you need to remember one revolution will be something like 1 200th off a unit
you count the number off revolutions required to move the last red dial 0ne point [i have assumed 2 revolutions] you then count the red dials as these are fractions off a unit
so the last black number is a unit followed by the first red is 10ths off a unit second red is 100ths off a unit so it may be as little as one unit or less a day
or 15p a day or less
it could off course be quite a bit more but that requires the disc to fly round
