if hw on and heating off and the stat light on and you turn the stat up does the valve then open etc ?
as it is now the lever has resistance on it so the heating port closed
see if the stat opens the valve with heating off.
do what you have done again but reset the valve first.
isolate fused spur, switch back on this will put the valve in relaxed position. heating closed hw open.
heating off at programmer hw on at programmer.
valve will have resistance.
then put wall stat up only does the lever go loose or not ?
