Is a switched FCU supplying a heated towel rail permitted in a bathroom if it's behind a fixed panel (used to hide supply pipes to shower)?
Having looked at the bathroom electrics guide (NICIEC) in the reference section the closest scenario seems to be that the 'space under bath is "outside zones" if only accessible with a tool'. The panel in question is located in zone 2 and requires the removal of 4 screws to gain access behind it.
If it was a new installation then I wouldn't put it there but I'd prefer not to have to move it unless I have to. Would an IP rated FCU be a possible solution as appearance isn't an issue?
