I've just had a new ringmain installed in the kitchen and various FCU's are running appliances..
One of the FCU's installed is unused and I intend to run two external lights. I've installed a metal knockout box around 50 cm's away from the FCU I intend to use and have run 1.5mm twin and earth from the FCU to the box.
Wiring from both lights is also in the box but I now need to know how to wire it all up..
I have 6 wires in total
From the FCU load
Live (Brown)
Neutral (Blue)
Earth (Green/yellow)
Light 1
Live (Brown)
Neutral (Blue)
Light 2
Live (Brown)
Neutral (Blue)
I have standard 1 gang, 2 way light switch I want to use which has 2 L's (Which I guess are the common) and then L1 & L2 on each switch.
How do I go about wiring it up so each light works on each switch?
Pete
From the FCU load
Live (Brown)
Neutral (Blue)
Light 1
Live (Brown)
Neutral (Blue)
Light 2
Live (Brown)
Neutral (Blue)
Pete
