You could run Line, Neutral and Earth from FCU to socket and just one cable from socket to switch like a normal light switch is wired.
Understood, but I would be concerned for safety having effectively a socket circuit and lighting circuit on the same plate. I am sure the professional sparks will advise!
- Its a double switch
Why?I would be concerned for safety having effectively a socket circuit and lighting circuit on the same plate.
Future changes can be done in the future.Only for future changes, perhaps?
Therefore...?Checking for live supply (or lack of) before doing any work is the first thing you should do
Whose fault would that be?but what if someone just thinks " drop the breakers on all the lighting circuits, that'll be OK now" They then get a surprise from the live on the other switch.
So - no problem then.As an example, the extractor hood in my kitchen was fed by plug and socket above the wall cabinets. It was looking a bit greasy and I thought I'd change to a new one when I was decorating. Drop the kitchen circuit, double check the socket. Still live!
Likely the hood is nearer the upstairs circuit.The socket was fed from the upstairs ring. Not something I was expecting but it had been wired that way for some unknown reason
Do you plan everything just in case you want something else one day?
Could you not run the switched socket from the lighting circuit? I presume this is for a table lamp?
will be used to run a 5amp socket.
other side will be used to run a 5amp socket.
