A picture paints a thousand words as they say. I see what you mean. Not seen that before but, AFAIK, a perfectly acceptable method.
One thing I cannot make out from the picture - are those posts in the middle (the large posts supporting the arris rails inside the fencing) angled at the top? Reason I ask is that they LOOK flat at the top and, if they ARE then that may be an issue.
But I digress...
I assume you will use cant rail as battens? As I said, I would be tempted to put a spacer between the sloping face of the cant rail and the brick wall. That way the only direct contact with the brick is at the fixing points which will have a very small surface area. Needless to say, use SS or similar product.
Again, all just IMHO. I am not an expert but there are plenty who are on here.
Regards,
B
But I digress...
Regards,
B
