Why I asked that was because, surely, lots of things which are not BS1363 are supplied from a ring final.Yes.Do you really mean from a ring final?
For example: washing machines, fridges, televisions et al.
The regulation in question, 433.1.204, says:
Accessories to BS1363 may be supplied through a ring final circuit.
It does not say:
Accessories to BS1363 may be supplied only through a ring final circuit - obviously not the case - or
Accessories to BS1363 only may be supplied through a ring final circuit.
What about grid switches?
Anything can be supplied through a ring final circuit (if the need arises, e.g. VD). The only difference in this case is the allowed reduced csa of the conductors and variable load sharing. What difference does that make to an accessory?
What difference is a radial final of the same characteristics?
We've had all this before.
Do you really want to debate it again?
