Fencing Problem
28 Aug 2009
Manchester
Hi Guys
I am replacing existing wooden fence panels that sit in slotted concrete posts and on a single gravel board.
The problem I have is with one of the panels is that a tree has grown at a slight angle and has split the existing panel see pic in FenceProb album for plan view.
There is another concrete fence post/panel that runs away from my fence and I am looking at using this to attach two smaller fence panels to "bend" the fence around the tree. (as per red lines in the diag)
What is the best way of attaching the new panels to concrete posts?
Thanks in advance
Daz
Has the tree leaned towards the fence, or does the stump actually sit on the boundary?
Cut the tree back, or lose the tree entirely if it's on the boundary. It will only continue to grow and damage the new panel.
The tree is leaning. At the base there is a gap of about 6 inches to the gravel board and it is the top 2 foot of the wooden panel where it intersects the fence.
Removing the tree is not an option I would want to consider as it adds to privacy.
Cheers
Daz
screw a batten to the tree, split a panel to fit either side of the tree and attach it to the batten on the tree. you cant remove the tree and bending a panel around it will only weaken the panel. a few screws in the tree wont harm it.
I put in an extra (wooden) post on the fence line, close to the tree. I cut a fence panel in half to fit, reducing the height of one half to fit under the tree trunk.
* Nail new battens to what will be the new edge of the panel before you cut it, otherwise it's likely to fall apart. *
