I have a Ferroli Falcon combi boiler that is again causing a problem. It is heating up ok and the water is heating constantly now. However the water is very hot when initially is turned on (with the heating on) then goes cold before the boiler ignites and heats the water ok. When the water is switched off it takes about a minute before the heating fires up again and there is a large cloud of what looks like steam out of the flue. After another minute there is a noise similar to air trapped and this cycles the heating off/on with the same happening. Pressure is about 1 bar going to nearly 2 bar when boiler is on. Can anyone suggest what it might be?
