spoke too soon!!!!!!
Question...... I have a 2 port valve on both the hot water and the central heating pipes.
When the cylinder stat calls for heat, the 2 port valve on the hot water pipe turns and when it finishes turning the pump starts, the boiler lights etc as normal.
When the cylinder stat is satisfied, the pump stops but the valve does not close at all, unless i turn the programmer switch to off on the hot water section. Is the 2 port valve on the water pipe supposed to close as soon as the cylinder stat is satisfied???
Thanks in advance.
Thanks in advance.
