many thanks for the information i will pass it onOne simple test any RGI can do is to measure the pressure presented by the venturi and compare it with the rated value of the safety device.
Tony
kind regards neil
Tony
thanks for the information greatly recived i will pass it onthe venturi should be white it is in two parts one is a double funnel the other is a staight with a hole drilled in the end,venturis are three coloured on these grey/white/red
grey are the originals[crap]
red were used to replace them
white were the latest design about five year ago,i could never find the difference visually,all i know is they worked and lasted longer than the others
prt no 39809790.
Eh?A blocked or broken venturi,maybe a fault on the air pressure switch,a bit of rain water in the air tubes.Does the thermistors and the limit stat not also control the when the fan runs?What fault would make a fan continue to run?
Dont you think that the PCB controls when the fan runs?
i can understand your reluctancy to give out any information that could result in injury or fatality ,
Kind regards Neil
Hi All, many thanks for the information supplied by your selves , most of the suggestions have been carried out by my engineers before joining this forum, my engineer will contact Bingo Bongo by phone today , Bingo Bongo will before giving out any information satisfy himself that the person on the other end of the phone is not me and a genuine bonafidy RGI , hopefully they will have a meaningful conversation and come to a stifactuary conclusion about my boiler , if this is the case then his approach to my situation should be looked at carefully and adopted more often a donation button for the upkeep of the forum would be a good way to thank people for the efforts they go to to help fault find, if the information published on this forum is so sensitive why is it not RGI members only , I agree the information supplied even at the level it is would entice the DIY’r have a go so it would be safer to supply all the information for DIY’r to finish the job ,not guess half way through or give no information at alli can understand your reluctancy to give out any information that could result in injury or fatality ,
Kind regards Neil
Kind regards Neil
In some cases the OP does seem to have some common sense and technical ability.
But we cannot give detailed instructions on DIY gas work on an open forum because anyone can read it and many with inadequate skills will be encouraged to have a go.
So the site makes a firm rule that no gas advice is to be given. My view is that in this thread the details written over step the site rules.
A gas engineer will ( usually ) be equipped with three items an average DIYer will not posess, a manometer, a flue gas analyser and an electronic gas leak detector.
Tony
At what point is the demand for heat removed when the boiler does not fire in the first place?The boiler senses a demand for heat and that starts the pump and then initiates the ignition sequence starting with the fan.
The ignition sequence ceases when the demand for heat is removed and in most cases the fan stops immediately although the pump over runs to remove heat from th boiler.
Tony
