Hi. I have a Ferroli Sigma 40-60 boiler installed March 2005. So is now out of 1 yr guarantee. This is a standard boiler (not combi) on a standard open vented central heating and hot water system with separate circulating pump in the airing cupboard. The boiler is wall-hung in the kitchen.
The problem is that the boiler starts up ok when water or heating calls for heat, but whn it first starts after the boiler has been on for 5 minutes it starts to vibrate itself and the pipework and then turns off! It then relights after a break of about a minute or so and cycles fairly normally after that.
The vibrating sounds like the water inside is boiling??? What may cause this and what may be the solution?
Thanks.
Thanks.
