Fibre optic master socket
17 Apr 2007
My sister has had BT fibre-optic installed, hence new master socket.
Can you run an extension phone cable from these types of master socket?
When you say "fiber optic" do you mean fiber to the cabinet or fiber to the premisis?
For fiber to the cabinet (by far the more common system) you should find the master socket has three parts. The front part is a normal NTE5 front and has a phone socket on the front and punchdown connections for extension phone wiring on the back. The middle part is the filter and has a socket for the VDSL modem on the front and some versions also have a pair of punchdown connections to allow an extension of the VDSL service. The back part is a standard NTE5 back and has the connections for the incoming BT wiring.
For fiber to the premisis voice may be delivered either over the existing analog line (having nothing to do with the fiber service and using the existing NTE5 unmodified) or be delivered over fiber in which case the phones have to be connected to the ONT. There is a special plate openreach can use to divert extesion wiring to the fiber voice service but I don't know if they always fit it and I've never seen it for sale seperately.
I assume fiber to the cabinet which is just the other side of the road from the house.
They are the first to be connected to this newly installed FibreOptic cabinet and they are delighted to have FibreOptic since they in a rural area and the ADSL was very poor at best.
Yeah you can, when you take the front off, there's terminals for broadband extensions (unfiltered) and telephone extensions (filtered).
