Greetings all!
I am trying to repair some floating shelves for a client.
They are poorly designed and hang by leaving two screws protruding from the wall onto which the shelf slots .
The supplied screws were barely long enough to hit brick and the plaster is old and crumbly.
No surprise that the shelves failed!
I tried to use much longer screws but after drilling the holes and getting the screws in, I discovered the screw heads are to big to fit in the slot holes on the back of the shelf.
Now I have great big holes that I need to fill with something that I can drill and fix screws closer to the original sized ones that will support the weight (and more) of the shelves.
I was thinking of drilling out the holes with a 10 mm bit and filling with epoxy putty, but that stuff is quite pricey.
Anyone have any recommendations?
Many thanks
Many thanks
