Filling holes in concrete floor left by bolts
8 Feb 2012
Essex
Firstly, my apologies if this is the wrong forum to post this. I wasn't quite sure what it'd best fit into.
We've just bought a new industrial unit and it has a 5,000 sq. foot warehouse. The previous occupants had racking installed and after removing it left about 90 10mm bolts left in the concrete floor.
We've managed to get these bolts out but of course, it's left 90 holes in the floor! The holes are about 1/2" diameter and 4" deep.
Now, what would be the best way to go about filling these holes in? I've seen various concrete compounds online but they all seem to require spreading when for holes, it would probably be better if we could inject it in.
Is there anything you could recommend we use?
Thanks woody. Whats the best nozzle to use? Also will it need cleaning before icing a cake?
Cool. I'd best get my pinny on then :)
I wasn't sure at first about just using cement, I thought that maybe it might not stick so well to the concrete around the hole and need some kind of epoxy or polyurethane compound to help it meld. That wouldn't be an issue?
