OK...it has been an ongoing saga......
I made a post a while back about the ongoing trials and tribulations of finding a window company who would install a proper lintel for the external leaf on a property.
https://www.diynot.com/diy/threads/...finally-got-quotes.489592/page-2#post-4017495
There is a timber lintel on the internal leaf, but no lintel on the external leaf.
I went through about 6 double glazing firms. Only one mentioned proper lintels, but they were so unreliable in getting back to me, I got the impression that the job was too much effort for them and there were cheaper and easier jobs to be had. All the others either mentioned re-enforced frames (bullshit) and angle irons.
I also went through about 4 builders, all of whom preferred to install angle irons. Which, from what I have read and from the opinions on here, is not the best solution.
I have finally found a builder, who on the initial telephone consultation said he would install catnic or equivalent without any suggestion from me. When I mentioned angle irons, he felt they were not appropriate, and a bit of a cheat, even though a lot of people used them.
This was good enough for me.
So, quote coming this week. A few questions though.
1) He did mention that for the lintels required on the second floor, beneath the render, that a concrete lintel would also be equally appropriate.
I am so cautious about the whole thing now I wanted to check with those on here.
As this has been dragging on for far too long, I also asked him if they would install the windows, to which he said yes.
2) So I wanted to check. Should any builder worth their salt have any issue installing upvc windows? Or is it such a specialised thing that I should still get a window company in to install them? Is there anything I have to be aware of with regard to building control if a builder is doing it rather than a fensa approved firm.
3) Should I also ensure a cavity tray and weep vents are installed as part of the installation of the new lintel? The internal timber lintel is staying on the large lounge window due to some ornate coving. Is there any benefit to replacing the timber lintels on the other windows? If the internal lintel stays, I assume a cavity tray should still be retrofitted.
Thank you in advance.
