Fire Alarms
System to comply to BS5446 Part 1 Smoke detectors to be Compliant with BS5839 Part6"
I think that's the wrong way round. BS 5446 Part 1 relates to smoke detectors. (And you may want heat detectors in certain locations.) BS 5839 relates to system design and specification.
sounds like a standard domestic (3 floor) smoke detector install.
so you will have probably been asked for one detector to each landing and a heat detector in the kitchen.
if you fit that (or better get your sparks to fit them, as they will need to be signed off) that should satisfy building control.
but yes you can add additional devices to the radial circuit to go into each room if you want, but check with manufacturers as to how many you can put on the radial circuit.
or you could go the whole hog and put a panel downstairs and fit a full 5839 system to LD2 / 3 if you want !!!! but it will cost you a pretty penny tho!!!
Oasis
I will be using heat detector in the Kitchen and Pantry
Oasis
I am alittle confused!
When orginally speaking to my architect, he told me I would need a detector in every room, Hallway etc.
I have been looking at a wired system and buy individual components to suite my needs.
A Panel with a backup battery system would set me back around 200£ with the detectors priced around 10 to 15£.
The question I have is I would have 3 floors, would I need 3 zones or would I need 1 zone alocated to 1 room?
What grade is it your fitting?
You can have detectors to each room, floors as zones with indicators outside doors. Or go fully addressable but this gets expensive. Then again indicators and extra cable offsets to a certain degree.
Not so easy is it designing a life protection system is it.
Is this for self contained rooms/flats? Or one home?
Time you just swallowed the bitter pill and got someone in to design it and install it and certify it.
Or you could do as others and have sh1te fitted, which does not work when tested. Moan about the cost but actually have a working system you can go to sleep safe in the knowledge it works.
Its for my home.
I would like to DIY as much as I can.
I have installed my own house alarm before
I guess I need to really read up alittle more about it and then decide that I want to do.
I did some basic reading today and will be going for a 3 Zone system with 1 zone for each floor.
Ground Floor
1x Heat Sensor in Kitchen
1x Heat Sensor in Pantry
2x Smoke detectors in the lounge and dining room
1x smoke detector in the hallway.
First Floor
5x Smoke detector in Rooms and bathroom
1x Smoke detector in Hallway.
Second Floor
3x Smoke detectors in Rooms
Smoke detectors in rooms will be installed closer to the door,
and the Hall ones will be located at the begining of the landing.
You need to read up more,
None in the bathroom.
30cm from doors and fittings if possible.
Smokes near kitchens are not too good.
Multi sensors are better in and halls.
Opticals in lounge and landings.
Ionisation in bedrooms.
Landings need to be near the higher points, as smoke rises.
The above is a brief description.
You still do not know what room has tripped.
Is this all interlinked or at a control panel?
to satisfy your building control officer you ONLY need to fit what i have told you above!
if you want to go the whole hog see and do what Alarm has said!
£10 to £15 quid for a smoke head ????
sorry i dont think so!!!
appolo S65 optical £34.56
base for a bove £4.23 plus vat
basic control panel inc back up batteries about £240.00
FP200 gold fire resistant cable £73.00 per 100m
sounders etc, test and inspection, certification, siting of devices in accrdance with BS5839 part 1 and 4 2002 BS 7671 etc etc etc
sorry mate but you might have fitted your own burgalr alarm, but a life safety ssytem is TOTALLY dirrent kettle of fish SP203 BAFE approved ?
Oasis
