It will fit 30 inch door. Opening is 700mm.
30" is not 700mm its 762mm
I thought fire doors come in 45mm thickness compared to normal 35mm?
You can get 35mm fire doors. you only really need FD 20 but FD30 are more common.
But the reduction I referred to was in the width. Fire doors can't be reduced much, so if you have a narrow or non-standard opening it may limit what doors are available to fit that frame
