Fire Rated Spots - Definitive answer anyone?
The onels that I have seen are open backed and look like any other IP downlight, although they have an additional fire gasket around the bezel of the frame!!
The home owner has just emailed me a copy of the report, which states -
4. Use of recessed light fittings in sloping or horizontal ceilings below roof voids (loft and kitchen roofs) is not accepted unless either: -
a. Fittings are of a type which have been tested and allow insulation to be fitted closely around the units
Or
b. Boxes are formed, or proprietary 'LoftCap' covers are used which allow insulation to be continuous around and above the fittings (not possible in this instance)
Lights should be altered or, works carried out, to ensure the number of light fittings used does not impair the integrity of insulation
** Jwhich suggests that fire spots would be the only option, fitted with Sylvania Coolfits. I personally don't know of any recessed fittings that are designed to allow insualtion to be fitted up to them? Seems to obviously be more about insualtion than fire retardant quality. [/b]
I don't know, but would a CFL downlighter be suitable to insulate right upto?
I recently wired a single storey kitchen extention, and the BCO would not allow any form of recessed spots due to them compromising the insulation in the void between the plasterboard ceiling and the roof tiles.
The customer and I settled on surface mounted fittings like these, which the BCO chappy was happy with too :)
