hi all,i have a firebird 9o oil fired combi, just coming up to 6 years old (biggest load of **** ever invented), i had to drain the tank to fix a leak, (common occurance)now when i switch it to hot water the limit stat trips after 5 or 6 mins, the cental heating works fine and it worked fine before i drained the tank, ive obviously upset something, im wondering if it is pressure related, should i check the pressure in the pressure vessel and would that cause it to trip?, oil tank is full, its regulary serviced, and was working fine till i touched it,
any suggestions?????
thanks
thanks
