Thanks guys, the product is plastic and double insulated, the instructions say not to earth it, I guess I snip the earth where I split the cable for the live and neutral to go into the spot?
What sort of wire are you using? That's not a problem I've ever had with normal twin and earth with solid cores. If you're using Flex, with multiple strands, maybe the screw connector is mincing the strands.Started well but wires tend to break when I screw the connectors to them and manipulate wires to fit in the pull cord switch. Probably happened 10 times now. Any advice welcome
