- Joined
- 7 Apr 2015
- Messages
- 2
- Reaction score
- 0
- Country
So ... After years of relying on the old man for help I've decided that I need to start getting the job done solo (apart from anything his eye is definitely out ... straight lines aren't so straight anymore !)
So, I am re-tiling a bathroom, pulling up the laminate floor and using 60/30 porcelain tiles for both the wall and floor.
The tiles will only be up to the coving around the bath (maybe considering buying some sort of wood and tiling that as the bath panel too ..?)
Now I've always either rushed or bodged things in my old flat but as I quite like my new house things need to start being done proper. So I have removed EVERYTHING in order to proerly tile and lay things back on top rather than put some dodgy cuts around the suite.
I've levelled the bath perfectly so will start from there and it will be a basic pattern, no small slithers on each end etc...
I've even gone as far as buting the LASH levelling clips to take the guess work out.
as you can under the laminate was some self levelling concrete and I took away the underlay.
Am I right in thinking that backer board is the way to go as some of the timber is still showing ???.... and do I need any sort of underlay ?
http://www.toppstiles.co.uk/tprod3920/section1061/Hardiebacker-500-Cement-Board-12mm.html
Also the walls appear pretty flat, I've removed all the old adhesive, sanded then sanded again... and again.
Finally I made the mistake of buying a cheap wickes tile cutter. Tried it once and it was shocking so will renting a rubi cutter for two days next week.
Any tips are very much appreciated.
My Albums Link: //www.diynot.com/network/djhackett1/albums/
