hi
i went to fit a new 2 gang dimmer unit today and think i may of got the wrong one.
Basically it is to replace the one at the bottom of the stairs. The one dimmer controls the lounge light, and the other is a 2 way circuit for the stairs light.
i managed to connect up the lounge light side fine - working ok.
the stairs light is a bit odd. on the back of the new unit there is a 3 terminals - L1, L2, and a wavy line with an arrow through it which is the dimmable output to the lamp.
I connected it up as per the old switch, and can turn the light on and off from the dimmer switch. I can also turn the light off from upstairs but cant then turn it back on untill i press the dimmer switch downstairs.
any ideas as to what might be up? as far as i could see there was a live feed into the switch unit, then a switched live up to the lounge light. that bits ok. then the live feed was linked to the L1 terminal, the black core (switched live) was then connected to L2, and the red core on the same cable connected to L2.
any help much appreciated.
cheers
cheers
