Great. As far as I am aware (as a non-plumber!), that's more-or-less what you are 'meant' to do. However, as has been said, be sure to read the pump manufacturer's instructions very carefully and make sure that you comply with them - otherwise youir warranty could be at risk.I've realised there is room for the pump on the shelf above the cylinder. Have fed the CWS down to just above the cylinder (low enough to fit the pump when it arrives) and will fit the surrey flange and use the side outlet of the flange and go up about a foot to connect to the pump also. Hopefully this will work.
Kind Regards, John.
