So, I've now taken the plunge and arranged for my installer to fit a new external expansion vessel in a couple of weeks. I'm supplying the parts as I can get employee discount and I'm in the process of putting a list together, which has caused me to wonder about a couple of things.
How easy is it to recharge an external expansion vessel? I'm assuming the whole CH system needs to be drained and the drain cock left open to enable the vessel to be charged properly. This seems like a lot of work - much harder than recharging the vessel in the boiler, which only requires the boiler to be drained! Is there a valve that can be included in the new vessel pipework to enable it to be isolated and only the vessel pipework be drained? I've read that you shouldn't isolate an external expansion vessel as this can be dangerous as there's nowhere for the pressure to go, although I still have a working EV in my Vaillant boiler, so maybe this isn't such an issue for my system.
I was thinking of getting an expansion vessel that would allow the diaphragm to be replaced should it ever perish, but the ones I've looked at seem to be sealed systems, so this isn't possible. Admittedly, they are cheaper than I thought, but it still feels wrong to have to throw one away, just because the diaphragm fails!
The return pipes are 22mm, so I assume 22mm pipe will be used to connect up to the EV, or does that depend on the make of the EV?
Finally, does anyone have any favorite EV manufacturers?
Thanks in advance for your helpful replies.
