Can someone please tell me where i can find the gas reg that quotes when installing a new gas carcass within a property you must fit an isolation tap to the gas fire if none was fitted before.
A little background to the question might help but in general terms if the gas supply around the property has been replaced then everything connected to it must comply with current regulations.
Therefore if no means of isolation was previously present then that would have been regarded as Not to Current Standard and to connect it to the new supply this defect would have to be rectified.
But a question in return why do you seem to be against the fitting of what is/or could be a vital safety device?
