I am in the process of fitting a Sanibest macerator, the discharge connector accomodates 32mm OD, 28mm OD and 22mm OD (solvent weld plastic) pipework. I am advised it is better to fit the larger pipe as 22mm is more easily blocked. However 32mm OD pipe is non-existent in the UK, and the 28mm virtually non-existent, so are Saniflow (French I believe) having a laugh?
I am thinking of connecting 22mm OD overflow pipe to the Sanibest connector and then converting immediately up to 32mm ID plastic pipe, but not sure in the Sanibest can handle the increased volume!
Any guidance appreciated.
thx
Lancelot
thx
Lancelot
