Fitting Expelair CF40
27 May 2010
I'm sorry if you've had this one before, but I'm about to embark on fitting the above fan into my kitchen.
I have a few questions if anyone has time to answer...
1) The fan connectors are: E, N, T, LH (High Speed), LL (Low Speed). Would the following be correct?
E (Ceiling Rose) > E (Fan)
N (Ceiling Rose) > DP Switch > N (Fan)
SL (Ceiling Rose) > DP Switch > LH (Fan)
The wiring instructions for the fan say to for the Live to go through a DP switch, through a fuse, split into 2: one to LH and one to T via optional lamp?
Can someone explain that to me as I'm lost - especially about splitting into 2 and the optional lamp? (google wiring diagram for clarification)
Secondly, I'm not yet sure whether the lighting ring has an Earth. What would the procedure be if there is no Earth in the lights?
I really appreciate any/all help on this one.
One other thing sorry.
In terms of situating the fan, would it be totally wrong to place it above the cooker between the back door and window. The replacement air should come from the kitchen door leading into the hallway rather than the back door, or window.
That's an easy one - don't fit the fan. Either get one that doesn't need an earth or, much much better, rewire the lighting circuit.
Unless it's sold as a cooker extractor fan it would be totally wrong.
Would it be an option to put it to a fused switch instead of the lights?
When I say above the cooker, I meant ceiling height above the cooker. Could you elaborate on why it would be so wrong to do that and where would be the best place to situate it?
I only have one external wall with the door being on the far left, the cooker almost behind the door, a large window and then approx 2 metres of wall with cupboards.
I appreciate all your input, but it would be really helpful if you could explain your answers a little more.
No they aren't. According to the diagram for the CF40 here they are E, N, T & LH.
Not according to the diagram for the CF40 here.
Do you want the fan to only be able to be switched on when the light is on, and for the timer, if it has one, not to work when you turn the light off?
No they don't - the diagram for the CF40 here shows the switched live going to T. How on earth can you think that this:
shows the live going to T via the lamp? The lamp is clearly connected between live & neutral.
Seriously - if you cannot understand an incredibly simple diagram like that, please get an electrician.
Whereabouts in the UK are you?
If I'm honest I don't understand the diagram. The electrician is certainly something I couldn't rule out, but I thought it would be a good opportunity to learn.
Rest assured, as obtuse as I clearly appear to you, I'm not quite so daft as to have a go without having a relatively clear picture of what I'm doing - even if I don't fully understand it.
If anyone feels like explaining the diagram in terms a 3 year old could understand, I truly would be very grateful indeed. :)
It will get clogged with grease.
That would be the best place to situate it.
I know that, but that's the one with the cooker on it! I meant my options are limited with regard to placement near to a cooker.
I would have opted for a extractor hood, but it's the old style cooker with the grill above and someone told me the hoods aren't so good with those.
What would you recommend to control the condensation?
