Hi All,
I've a question for gas safe engineers please.
Just had a boiler service and the engineer nearly cut my supply and issued an ID because he found a "socket-formed" capillary soldered joint in the gas supply. (BTW I'm not sure if I have the correct name for this joint, but basically where you widened the end of a copper pipe using a "socket former" which can then be pushed over a pipe of the same size and soldered). He said only slip on copper fittings were permitted in gas pipework. As the "socket-formed" joint was installed by a previous gas safe engineer, I'm wondering if these fittings are indeed dangerous and illegal as suggested by the current gas service engineer.
