I got told which fire i needed so bought one for a pre cast flue . My gas supply is capped at the moment so would like to fit the marble fire myself then get a gas installer to fit fire.
What do i need to do to fit the surround and back panel as i would like to do these myself , i've got a good understanding of diy jobs as i'm a maintenance electrician
Do you fit back panel straight to the wall or bring it to the edge of fire surround then seal around that which would mean putting something between wall and back panel and also do you need to seal around fire surround itself.
This is the fire place that needs fitting - link below
http://www.internetfiresdirect.co.uk/showdetails.asp?id=1234
Loads of help would be grateful cheers
