Single and earth too, yes. I helped on a rewire in 1982 when it was used and have seen it on younger installs, although by around the mid-late 80's, it was dying out.
I guessed/assumed that we were talking about lighting circuits, but I was wondering what single+earth cable was commonly be used for (functionally) within such circuits - since it not obvious (to me!).
Split loop systems where the neutrals are looped at the ceiling rose and lines at the switches for maximum inconvenience.
Other uses include borrowed neutral mess where morons have added wall lights with a single line from the ceiling rose and a single neutral from a nearby socket outlet, two lights in the same room wired in series, and bizarre switching arrangements which never work properly.
Split loop systems where the neutrals are looped at the ceiling rose and lines at the switches for maximum inconvenience. .... Other uses include borrowed neutral mess where morons have added wall lights with a single line from the ceiling rose and a single neutral from a nearby socket outlet, two lights in the same room wired in series, and bizarre switching arrangements which never work properly.
Thanks. That seems broadly consistent with the fact that I could think of very few situations in which single+earth cable would be used (for a sensible, reasonable and legitimate reason.
The examples you give are of things that caused 'maximum inconvenience', 'never worked properly' and/or were 'done by morons'. Does that mean that there were very few situations in which a competent and sensible electrician would have used such cable?
