I've just bought a new light fitting which actually consists of three individual pendant lamps which need to be individually wired (i.e. it is basically three hanging lights which are fixed to a ceiling plate).
The existing light fitting is the standard plastic ceiling rose (new property) with two circuit cables and one for the switch. The new light fitting has not come pre-wired but included a small Ashley 20amp junction box - this is nowhere near big enough to connect the three light flexes and three circuit cables.
I was thinking about just getting some terminal connectors and wiring all the three light flexes/circuit cables together and then enclosing them in a choc box. Within the base plate/ceiling rose which came with the light there is about 30mm of space so was hoping I could place the choc box into this space.
Alternatively, if there isn't enough space for the choc box within the light fitting, would I need to put a junction box in the ceiling void and run the three flexes into this? The only problem is getting access to the void without lifting the boards in the room above - so was hoping that the terminal connectors/choc box is an acceptable solution?
Any advice on the above would be very much appreciated. If I was to use terminal connectors, would any size be okay as long as a minimum of 5 amp was used?
Perhaps I need to get a spark to do the above but would still be interested in any advice.
Many thanks as ever,
Damian
Damian
