- Joined
- 22 Jan 2021
- Messages
- 116
- Reaction score
- 1
- Country
Hi All,
Probably a simple question but driving me nuts. Fitting an interior sill, the gap at either side of the sill (wall back to window) is different by about 20mm.
If I fit the sill butted to window, cut at same depth right across, I end up with the overhang and sill horns different at each end. This is noticeable against radiator underneath - looks like something is running off.
What's the solution here, do I ensure overhang at each end is the same and therefore scribe back of the sill to the window or do you just do it parallel to window regardless and end up with different overhangs at each end?
Thanks for any advice!
