Unusually the Americans have ruled out military force.
http://www.telegraph.co.uk/earth/en...lls-to-take-control-of-oil-spill.html[/QUOTE]
Guess that means there are no British soldiers there for them to aim at then (ooops, off topic, sorry )
the balloon is not a bad idea.. you'd have to insert it with a pipe so it's a long way in and then pump it full of a liquid cement or something..
A ratchet umbrella type thing. Hard bit will be getting it into the pipe I suppose.A balloon is a silly idea. Better some kind of Rawl Bolt that opens up.
Denso tapeHow would you remove the rawl bolt after welding the repair...??????
how will they remove the concrete they plan on pumping into it?
answer is you don't.. you cap the pipe, encase it is concrete and forget about it, then drill a new well..
