The lockout happens every time, perfectly replicatable. PRess the red button and it happens again and again and again.
I've looked at the service manual diagnostic flowchart. There are some things to check (with a multimeter) and some which I can't check as they are gas related.
I have noticed that the GAS IN pipe (the middle one of 5)has a yellow lever which is vertical whereas the COLD WATER IN pipe has a blue lever of which the long part is pointing 250 degrees.
Its clearly not in the right position (nearly off!) so what is best safe practice to TRY to free this blue lever?
I also noticed green scale above the lever valve so I presume there is a tiny bit of a leak unnoticed. Would this reduced water input due to the water in restriction, cause any lockout problems? My sense tells me it does not, but I thought I would ask so its clear straight away.
IT seems that the flowchart points to the gas side being a problem (gets to ignition spark stage but no gas to ignite..). All I can do is check with a meter any pcb circuits related to opening the gas valve. I have noticed a gas "modulating operator" on the leftmost side of the main circuit board. It states ~21volts in the manual.
I think this is the correct set of pins to check which I'll do tomorrow.
So, I'm just wondering if there are any tips floating around?
