fixing clad to old soffit?
3 Nov 2007
i am planning on cladding my soffit and fascia board. The old asbestos soffit sits in a grove in the fascia board, then rests on top of the external brick work and is nailed down to it. I plan to over board this, how should i fix the back of the board up? i can't reach in from the loft to hold timber there for screws, and there is no timber there from the roof. My only thought was to use spring toggles but that would mean making a hole in the old boards, then i would put a cao on the screw. thanks
You would normal fix a U channel to the wall to hold the soffit board there, and then drop the new fascia a bit so that the new soffit slots between it and the bottom of the old fascia.
Or use an external "no nails" adhesive!
i see that might work, might be tricky getting it in the channel but also it would be hard to get the channel so near the top of the bricks. I think ill use some adhesive and prop it up with some wood un til it drys.
