I am just starting the internal fit out of my extension which I have built myself so far.
The walls are dense concrete block and require 70mm celotex and then plasterboard.
There will be no battens. (architect spec)
I would prefer to use separate insulation and PB due to significant cost saving.
How do I fix the insulation to the blocks and then how do I fix the PB on top?
Should I be avoiding foil faced insulation?
I cat find much info online.
Thanks,
Shaun
Thanks,
Shaun
