Fixing plasterboard to breze block
Thanks for the tip - i will check out the dry fix foam - does this mean i don't need adhesive? if i do - what sort of adhesive would you recommend? also - the insulation richard sugested - can i cut it to fit or do i need to buy the right sized pieces? thanks guys
hi there you dont need adhesive you just need the dry fix foam that is the adhesive and you also need a special foam gun it operates at higher pressure than normal expanding foam so you need this higher pressure gun mine cost £20 at my local builders merchants but has paid for itself many times over
where do you get the dry fix from? i have found a similar thing in BandQ but it says for windows and door fixings but doesnt mention plasterboard.
Dry fix foam adhesive;
http://www.ps-tools.com/catalog/everbuild-pink-grip-dry-fix-plasterboard-foam-750ml-p-4915.html
It’s a fairly new development &, personally, I’ve not tried it but would be very wary of using foam fix on anything other than dry lining on a nice flat new build wall. I will definitely be giving it a bit more time on the market before I give it a try; the last thing you want is the boards on the floor in a couple of years time. It’s also quiet expensive & I think you’ll end up using a lot more of it than traditional Drywall adhesive, especially on uneven walls where I suspect it wont be as versatile.
I recommended using cavity insulation bats in your case;
http://www.sigexpress.co.uk/Cavity-Wall-Insulation/Cavity-Wall-System.htm
Where necessary, just cut them to size with a Stanley knife.
hi im a joiner general builder and i use to use plasterboard adhesive but i have used this foam on loads of kitchens bathrooms conversions and honestly its brilliant i was a bit wary at first but not any more i can buy the foam in liverpool for £7 a can the manufacturers say it does 5 8by4 sheets of plasterboard but i have only got 4 sheets from a can it may be slightly more expensive than normal adhesive but its so much quicker and less messy i have used it on uneven walls and brickwork and it sticks brilliantly try it and dont think you will go back to mixing adhesive just my opinion
