I need to attach 2 X 3cm x 3.5cm Stainless Steel Pad Eye to the concrete wall at the back of my house to attach a rectangular shade sail
The company where I bought the shade sail have a decent installation guide here but dont specify how you should fix the pad eyes to the house.
The wall itself was built only a few years ago and if I remember correctly is a cavity wall with insulation in the middle. The width of the wall itself is about 30cm so the concrete block is probably the standard of about maybe 100mm I guess.
The shade sail will be also be attached to 2 X 125mm round wooden posts which have already been installed and will connect to these eye bolts which are fairly chunky.
The place I bought the pad eyes doesn't have much technical details but similar pad eyes here do. The width of the hole for screws are about 4mm wide so I'm not sure what type of screw I should use and if I should use a plug or not.
These masonry screws seem like what I'm after but they are 7.5mm wide so too big.
Any advice would be greatly appreciated as I'm hoping to fix the shade sail tomorrow, Thursday.
Thanks,
Ciaran
Thanks,
Ciaran
