A good plasterer can and will make a crooked wall straight.
Big straight edge is all you need and should be part of any good plasterers's tool kit.
Here in the province you don't have to trail after other tradesman with a tube of caulk!
You can plaster to the floor as long as the room is swept and hoovered.The plasterers that work on my jobs also don't plaster to the floor which makes a good finish on skirting awkward, their excuse is that they don't want to drag the s**t that's on the floor up the walls! Horlicks!!!
I fit our skirting so i know what it is like. When I skim walls I try and make sure i run the trowel along the base of the wall to avoid that inevitable lip of skim that always kicks the skirting at the bottom.
When I skim walls
In my case what would be the safest way to remove or smooth off that lip at the bottom?
bosch gbh drill with clutch facility,when i was on site this was an absolute god send,matter of minutes.
Is that not a bit excessive?
You say that as if skimming is a dark secret. I have been plastering for aboot 30yrs. Back in the day we used carlite browning and carlite skimming. Tough work. Skimming boards is a doddle compared to wet plastering.You don't surely do your own skimming?
Funny.Why don't you get a pro in?
Hilarious.How many tubes of caulk do you go through?
