I live in an Edwardian semi, with solid brick walls and fairly shallow foundations. Our house has had serious attacks of woodworm in the past, and many joists and floorboards are thoroughly riddled with holes.
I want to stop it coming back, so keeping humidity from getting too high is important.
Under our lounge and dining room the crawlspace has always looked damp. There is no water, but lots of almost muddy looking soil.
Yesterday I installed a remote humidity detector down there and it reads 75%. It's an expensive, reliable meter that I've used for months and in the house above humidity is generally around 60-62%, which is fine.
So what should I do?
I've read about putting down a barrier on the ground, and encapsulating the whole crawl space. But is that worth doing? What else would you do?
